0 Replies Latest reply on Nov 11, 2008 5:41 PM by Jason Szeto
    [svn] 4078: Add support for dataTips to Slider
    Jason Szeto Level 3
      Revision: 4078
      Author: jszeto@adobe.com
      Date: 2008-11-11 17:41:52 -0800 (Tue, 11 Nov 2008)
      Log Message:
      SDK-16291 Implement data tip for slider
      - Added new dynamic, optional skin part called "dataTip".
      - Added dataTipFormatFunction, dataTipPrecision and showDataTip properties
      - Added protected function positionDataTip
      - Added dataTip skin part to FxHSliderSkin and FxVSliderSkin
      - data tip is an IDataRenderer, so it can render any type of data
      The data tip appearance is defined entirely by the skin. The position of the
      data tip is calculated using a combination of the skin and the Slider controller.
      The following properties were not retained from the Halo Slider:
      - sliderDataTipClass (the skin part allows the developer to define the data tip type)
      - dataTipStyleName (styling is defined on the skin part)
      - dataTipOffset (the offset position is defined in the skin part)
      SDK-16823 - Gumbo Slider does not support scroll wheel to increment / decrement value
      Slider listens for scroll wheel events anywhere on or off the stage while it has focus.
      QE Notes: Test new properties, functions and data tip behavior
      Doc Notes: Added new properties and functions
      Bugs: SDK-16291, SDK-16823
      Reviewer: Glenn and Gordon
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-16291
      http://bugs.adobe.com/jira/browse/SDK-16823
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxHSlider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxVSlider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxSlider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxTrackBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVSliderSkin.mxml
