0 Replies Latest reply on Nov 12, 2008 1:23 PM by Gaurav J
    [svn] 4089: Adding new option called exclude-sources to asdoc.
    Gaurav J Adobe Employee
      Revision: 4089<br />Author:   gauravj@adobe.com<br />Date:     2008-11-12 13:23:23 -0800 (Wed, 12 Nov 2008)<br /><br />Log Message:<br />-----------<br />Adding new option called exclude-sources to asdoc. This should be useful when doc-sources is used and there are files which can not be compiled independently (like an include file).<br /><br />exclude-sources requires the path to the file or folder that should be excluded.<br />Also adding support to <asdoc> task.<br /><br />QE Notes: None<br />Doc Notes: None <br />Reviewer: Paul<br />Bugs: SDK-16545<br />tests: checkintests<br /><br />Ticket Links:<br />------------<br />    http://bugs.adobe.com/jira/browse/SDK-16545<br /><br />Modified Paths:<br />--------------<br />    flex/sdk/trunk/modules/antTasks/src/flex/ant/AsDocTask.java<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_en.properties<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDocConfiguration.java
