0 Replies Latest reply on Mar 19, 2008 10:44 PM by (Jono_Spiro)
    [svn] 873: modules: eliminating serialization warnings.
    Level 1
      Revision: 873
      Author: jspiro@adobe.com
      Date: 2008-03-19 23:44:38 -0700 (Wed, 19 Mar 2008)
      Log Message:
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flash/css/Descriptor.java
      flex/sdk/trunk/modules/compiler/src/java/flash/css/FontFaceRule.java
      flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleParser.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerException.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerSwcContext.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/FileSpec.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/LicenseException.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SourceList.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SourcePath.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/TranscoderException.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/MetaDataEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/MetaDataParser.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/StyleEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SyntaxTreeEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableFirstPassEval uator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableSecondPassEva luator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeSecondPassEv aluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/ManagedExtensionError .java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/ManagedFirstPassEvalu ator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/NodeMagic.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/ClassTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/ConfigurationException.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/FontsConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/FileConfigurator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/ConditionTypeNotSupported.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/ParseError.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/SelectorTypeNotSupported.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleConflictException.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/PropertyText.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/TranslationException.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/AbstractTranscoder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/ImageTranscoder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/MovieTranscoder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/SkinTranscoder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/SoundTranscoder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/HTTPServiceAnalyzer .java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/RemoteObjectAnalyze r.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/SyntaxAnalyzer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/WebServiceAnalyzer. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AnonymousObjectGraph Builder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ApplicationBuilder.j ava
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ArrayBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/Builder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ModelBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/PrimitiveBuilder.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/XMLBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/XMLListBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/AnalyzerAdapter.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/Scanner.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/ScannerError.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/CodeFragmentList.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/AtEmbed.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/AtResource.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Swc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcCache.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/Benchmark.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/CompilerMessage.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/IteratorList.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/LinkedQNameMap.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/LocalLogger.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/MD5Crypt.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/ManifestParser.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/OrderedProperties.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/QNameList.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/QNameMap.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/QNameSet.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/VelocityException.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/VelocityManager.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/XMLStringSerializer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Optimizer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/SimpleShell.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Tool.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ToolsConfiguration.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/CommandLineException.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/InProgressException.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/NoResponseException.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/NotConnectedException.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/NotSuspendedException.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/PlayerDebugException.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/SuspendedException.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/VersionException.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/expression/IncompleteExpres sionException.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/expression/NoChildException .java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/expression/NoSuchVariableEx ception.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/expression/PlayerFaultExcep tion.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/expression/UnknownOperation Exception.java
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/AmbiguousException.java
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/NoMatchException.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fonts/LocalFont.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/SwfFormatException.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/TagDecoder.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tools/Disassembler.java
