0 Replies Latest reply on Nov 20, 2008 5:16 PM by (Paul_Reilly)
    [svn] 4154: * Fixed compiling libraries with Flex Builder.
      Revision: 4154
      Author: preilly@adobe.com
      Date: 2008-11-20 17:16:30 -0800 (Thu, 20 Nov 2008)
      Log Message:
      tests Passed: checkintests, performance test suite (Alta, Hospital, frameworks)
      Needs QA: YES
      Needs DOC: NO
      API Change: NO
      Reviewer: Pete F.
      Code-level description of changes:
      tools/oem/Library.java
      Modified link() to check "out" output stream first, then "output"
      file name, because Flex Builder supplies both, but they only use
      the "out".
      compiler/swc/SwcDynamicArchive.java
      Added support for saving to output stream instead of a file.
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcDynamicArchive.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
