0 Replies Latest reply on Nov 20, 2008 8:21 PM by (Tom_Harwood)
    [svn] 4156: - Make parameter types nullable to follow the AVM verifier logic.
      Revision: 4156
      Author: tharwood@adobe.com
      Date: 2008-11-20 20:21:29 -0800 (Thu, 20 Nov 2008)
      Log Message:
      - Fix method name processing so -preserve_method_names works
      - Factor out redundant backwards branch logic on edges, just look at the TO block
      - Temp. fix to always coerce backedges in -legacy_verifier mode, the verifier
      simulator needs to feed per-block nullable info to verify_eval. Worst-casing
      it generates correct if redundant casts on backedges.
      Modified Paths:
      flex/sdk/trunk/modules/asc/src/java/adobe/abc/GlobalOptimizer.java
