0 Replies Latest reply on Dec 12, 2008 12:27 PM by Gaurav J
    [svn] 4298: ASDoc Bug fixes for:
    Gaurav J Adobe Employee
      Revision: 4298
      Author: gauravj@adobe.com
      Date: 2008-12-12 12:27:08 -0800 (Fri, 12 Dec 2008)
      Log Message:
      Inserting the [native] metadata tag between a class ASDoc comment and the class definition causes ASDoc to omit output for the class.
      Missing param description when using @copy tag.
      ASDoc comments on metadata tags other than Event, Effect, and Style should be applied to the next class element.
      Also making change to CompilerAPI.java so source from swc doesn't take precedence over source from disk.
      QE Notes: Some baselines need to updated.
      Doc Notes: None
      Bugs: SDK-18413, SDK-18415, SDK-18388
      tests: checkintests, asdoc
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-18413
      http://bugs.adobe.com/jira/browse/SDK-18415
      http://bugs.adobe.com/jira/browse/SDK-18388
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsClass.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/ClassTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/TopLevelClassesGenerator.ja va
