0 Replies Latest reply on Dec 16, 2008 9:49 AM by (Corey_Lucier)
    [svn] 4329: A fix for Thermo team.
      Revision: 4329
      Author: clucier@adobe.com
      Date: 2008-12-16 09:49:19 -0800 (Tue, 16 Dec 2008)
      Log Message:
      A fix for Thermo team. If an element does not exist when a SetProperty override is applied, the override should not then try to restore the value later (null) when the override is removed.
      QE Notes: None
      Doc Notes: None
      Bugs : None
      Tests: checkintests
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/states/SetProperty.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/states/SetStyle.as
