0 Replies Latest reply on Dec 16, 2008 1:45 PM by (Paul_Reilly)
    [svn] 4330: * Reduced code generation for Bindable, added weak reference support
      Revision: 4330
      Author: preilly@adobe.com
      Date: 2008-12-16 13:45:10 -0800 (Tue, 16 Dec 2008)
      Log Message:
      to BindingUtils and added support for binding to private Statics.
      tests Passed: checkintests, mxunit databinding (with and without AST generation)
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-14891
      API Change: Yes, see BindingUtils and IWatcherSetupUtil2.
      Reviewer: Corey
      Code-level description of changes:
      frameworks/projects/framework/src/mx/binding/utils/ChangeWatcher.as
      Added useWeakReference arg to watch().
      Added useWeakReference variable.
      Modified reset() to use useWeakReference.
      frameworks/projects/framework/src/mx/binding/utils/BindingUtils.as
      Added useWeakReference arg to bindProperty() and bindSetter().
      frameworks/projects/framework/src/mx/binding/BindingManager.as
      Added set() function.
      frameworks/projects/framework/src/mx/binding/IWatcherSetupUtil2.as
      Initial checkin.
      modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeSecondPassEvaluator.java
      Renamed ensureNonPublic() to ensurePublic() and reversed the logic.
      Renamed makeAttrListPrivate() to makeAttrListPublic() and modified
      to use ensurePublic().
      modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension.java
      Updated AST generation to mirror changes to WatcherSetupUtil.vm.
      modules/compiler/src/java/flex2/compiler/as3/binding/BindableProperty.vm
      Modified setter code generation to use BindingManager.set() to
      reduce code size.
      modules/compiler/src/java/flex2/compiler/as3/binding/WatcherSetupUtil.vm
      Added support for staticPropertyGetter.
      modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
      Updated WatcherSetupUtil imports.
      modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
      Added static property getter arg to WatcherSetupUtil setup() call.
      Updated template to use IWatcherSetupUtil2.
      modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      Updated AST generation to mirror changes to ClassDefLib.vm.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-14891
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/binding/BindingManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/binding/PropertyWatcher.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/binding/StaticPropertyWatcher.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/binding/utils/BindingUtils.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/binding/utils/ChangeWatcher.as
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SignatureEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableProperty.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/WatcherSetupUtil.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeSecondPassEv aluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/NameFormatter.java
      Added Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/binding/IWatcherSetupUtil2.as
