Revision: 4334
Author: gruehle@adobe.com
Date: 2008-12-16 16:44:11 -0800 (Tue, 16 Dec 2008)
Log Message:
Removed DropShadowFilter from the ScrollBar and NumericStepper/Spinner button skins. These were added as part of the styling changes in revision 4314 but caused a large increase in memory usage. These have been replaced with gradient approximations.
Added initial skin for ButtonBar. The corners of the first/last button skins get distorted when the buttons are resized. This will be fixed once scale grid support is done.
Fixed style metadata name problem: highlightColor should be rollOverColor.
QE Notes: Bitmap tests for scrollbar and numeric stepper/spinner need to be updated.
Doc Notes: None
Bugs: SDK-18452
Tests: checkintets
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-18452
Modified Paths:
flex/sdk/trunk/frameworks/projects/flex4/src/Flex4Classes.as
flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonBarSkin.mxml
flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxScrollBarDownButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxScrollBarLeftButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxScrollBarRightButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxScrollBarUpButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxSpinnerDecrButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxSpinnerIncrButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/metadata/SparkColorStyles.as
Added Paths:
flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonBarFirstButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonBarLastButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonBarMiddleButtonSkin.mxml
