0 Replies Latest reply on Dec 18, 2008 1:24 PM by (Paul_Reilly)
    [svn] 4354: * Further reduction of data binding code size.
    Level 1
      Revision: 4354
      Author: preilly@adobe.com
      Date: 2008-12-18 13:24:42 -0800 (Thu, 18 Dec 2008)
      Log Message:
      tests Passed: checkintests, mxunit data binding
      Needs QA: YES
      Needs DOC: NO
      API Change: NO
      Reviewer: Corey
      Code-level description of changes:
      frameworks/projects/framework/src/mx/binding/Binding.as
      Added defaultDestFunc() and modified constructor to use it if
      destFunc is null.
      modules/compiler/src/java/flex2/compiler/as3/binding/BindableFirstPassEvaluator.java
      modules/compiler/src/java/flex2/compiler/css/StyleDef.vm
      Cleaned up unused imports.
      modules/compiler/src/java/flex2/compiler/css/FontFaceRules.vm
      Removed "extends Sprite".
      modules/compiler/src/java/flex2/compiler/mxml/rep/BindingExpression.java
      Added isSimpleChain().
      modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
      Reduced lines of code in _bindingsSetup().
      modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      Equivalent to changes me to ClassDefLib.vm.
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/binding/Binding.as
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableFirstPassEval uator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/FontFaceRules.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/BindingExpression.java
