0 Replies Latest reply on Dec 22, 2008 4:24 PM by Jason Szeto
    [svn] 4378: BitmapFill Bug fixes and minor Group mask change
    Jason Szeto Level 3
      Revision: 4378
      Author: jszeto@adobe.com
      Date: 2008-12-22 16:24:54 -0800 (Mon, 22 Dec 2008)
      Log Message:
      SDK-18378 BitmapFill rotation property not rotating correctly
      Change code to use radians instead of angles
      SDK-18345 Cannot change BitmapFill source property at runtime using ActionScript
      Fixed logic in source setter
      SDK-18344 Setting BitmapFill source dynamically at runtime doesnt immediately update the display list.
      Dispatch PropertyChange event from source setter
      * Added transformX, transformY, x, y
      These properties are defined in the FXG spec, but were missing.
      * Deprecated originX, originY, offsetX, offsetY
      These are replaced by transformX, transformY, x, and y.
      * Fixed setting source to null
      * Fixed originX/Y logic
      Code now translates the bitmap back
      * Fixed position when sharing displayObject
      Take into account the position of the bounds passed into the begin function.
      * Moved Group's mask and maskType logic from commitProperties to updateDisplayList
      QE Notes: Need updated tests for BitmapFill.
      - add transformX, transformY, x, y.
      - test setting source to null, or changing source
      - test position when you have multiple GraphicElements sharing the same displayObject
      - test setting rotation
      Doc Notes: Need doc for transformX, transformY, x and y.
      Bugs: SDK-18378, SDK-18345, SDK-18344
      Reviewer:
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-18378
      http://bugs.adobe.com/jira/browse/SDK-18345
      http://bugs.adobe.com/jira/browse/SDK-18344
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/Group.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/GroupBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/GraphicElement.a s
      flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/BitmapFill.as
