0 Replies Latest reply on Jan 6, 2009 8:50 AM by (Darrell_Loverin)
    [svn] 4406: Change tests that generate bits of Style-related code.
      Revision: 4406
      Author: dloverin@adobe.com
      Date: 2009-01-06 08:50:31 -0800 (Tue, 06 Jan 2009)
      Log Message:
      Change tests that generate bits of Style-related code. Where the tests used to test for FxContainer they now test for ISimpleStyleClient. The changes only impact Gumbo applications, Flex3 and older applications will continue to be tested for LayoutContainer.
      QE Notes: None
      Doc Notes: None
      Bugs: None
      Reviewer: Paul
      tests: checkintests
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
