0 Replies Latest reply on Jan 7, 2009 9:50 AM by (Paul_Reilly)
    [svn] 4421: * Implemented signature sorting for imports, use namespaces,
      Revision: 4421
      Author: preilly@adobe.com
      Date: 2009-01-07 09:50:25 -0800 (Wed, 07 Jan 2009)
      Log Message:
      variables, functions, classes and interfaces, plus associated
      metadata. This should speed up compile times when the items listed
      above are moved around.
      * Implemented human readable option with signature generation. Human
      readable is only on when keepGeneratedSignatures is true. When it's
      off, only essential info is added to the signature and abbreviations
      are used for keywords. This should speed up compile times and
      reduce compiler memory use.
      tests Passed: checkintests, compilerperformance (the four failing
      invalidation tests should be removed)
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-18480
      API Change: NO
      Reviewer: Gaurav
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-18480
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SignatureEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SignatureExtension.java
