0 Replies Latest reply on Jan 8, 2009 5:53 PM by (GordonSmith)
    [svn] 4460: Renamed UIComponentAccImpl to UIComponentAccProps because it extends AccessibilityProperties , not AccessibilityImplementation.
    Level 1
      Revision: 4460
      Author: gosmith@adobe.com
      Date: 2009-01-08 17:53:33 -0800 (Thu, 08 Jan 2009)
      Log Message:
      Renamed UIComponentAccImpl to UIComponentAccProps because it extends AccessibilityProperties, not AccessibilityImplementation.
      Added comments with the identifier for each magic role constant, so that it is easier to understand what roles our components are using.
      Moved two static methods from UIComponentAccProperties to AccImpl because they make more sense there.
      QE Notes: None
      Doc Notes: None
      Bugs: None
      Reviewer: None (no functional changes)
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/AccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/AccordionHeaderAccImpl. as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/AlertAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/ButtonAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/CheckBoxAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/ColorPickerAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/ComboBaseAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/DataGridAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/DateChooserAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/DateFieldAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/LinkButtonAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/ListBaseAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/MenuAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/MenuBarAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/PanelAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/RadioButtonAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/SliderAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/TabBarAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/TreeAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      Added Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/UIComponentAccProps.as
      Removed Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/UIComponentAccImpl.as
