0 Replies Latest reply on Mar 27, 2008 7:02 AM by (Paul_Reilly)
    [svn] 954: Fixed ASC so that Context.input can be null.
    Level 1
      Revision: 954
      Author: preilly@adobe.com
      Date: 2008-03-27 08:02:13 -0700 (Thu, 27 Mar 2008)
      Log Message:
      Fixed ASC so that Context.input can be null. This will be the case
      when the AST (abstract syntax tree) is generated.
      checkintests Passed: YES
      Needs QA: NO
      Needs DOC: NO
      API Change: NO
      Code-level description of changes:
      asc/semantics/CodeGenerator.java
      Added checks for a null context.input before using it.
      asc/parser/SelectorNode.java
      Made class abstract, so SyntaxTreeDumper can be sure that it
      doesn't have to handle this class directly, only it's subclasses.
      asc/parser/PackageIdentifiersNode.java
      Made IS_DEFINITION_FLAG private and added isDefinition() for use
      by SyntaxTreeDumper and toString().
      asc/embedding/LintEvaluator.java
      Modified Paths:
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/LintEvaluator.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/PackageIdentifiersNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/SelectorNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/CodeGenerator.java
