0 Replies Latest reply on Jan 9, 2009 10:47 AM by (Darrell_Loverin)
    [svn] 4475: Add colorCorrection property to FxApplication.
    Level 1
      Revision: 4475
      Author: dloverin@adobe.com
      Date: 2009-01-09 10:47:20 -0800 (Fri, 09 Jan 2009)
      Log Message:
      Since the colorCorrection property on FxApplication is just a proxy for the Flash Player's Stage.colorCorrection property, the compiler generates code that waits until after the application has been added to the stage to set the property.
      QE Notes: None
      Doc Notes: None
      Bugs: SDK-17869
      Reviewer: Alex, Paul
      tests: checkintests
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-17869
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxApplication.as
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDef.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
