0 Replies Latest reply on Jan 12, 2009 10:41 AM by Chet Haase
    [svn] 4486: Bitmap/shader transition feature, along with FxWipe and FxCrossFade, the two concrete effects based on this new shader-based transition infrastructure .
    Chet Haase Level 3
      Revision: 4486
      Author: chaase@adobe.com
      Date: 2009-01-12 10:41:56 -0800 (Mon, 12 Jan 2009)
      Log Message:
      Bitmap/shader transition feature, along with FxWipe and FxCrossFade, the two concrete effects based on this new shader-based transition infrastructure.
      QE Notes: None
      Doc Notes: None
      Bugs:
      Reviewer: Corey
      Tests: checkintests, Mustella: Effects, gumbo/effects, ListDataEffects
      Modified Paths:
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/manifest.xml
      Added Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxAnimateShaderTransition.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxCrossFade.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxCrossFade.pbj
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxCrossFade.pbk
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxWipe.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxWipe.pbj
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxWipe.pbk
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/WipeDirection.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAnimateShaderTran sitionInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxWipeInstance.as
