Revision: 4488
Author: gauravj@adobe.com
Date: 2009-01-12 12:10:58 -0800 (Mon, 12 Jan 2009)
Log Message:
Attempt to fix the heap-space issue with the doc target.
Also removing some unused code.
QE Notes: None
Doc Notes: None
tests: checkintests
Modified Paths:
flex/sdk/trunk/frameworks/projects/airframework/build.xml
flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
flex/sdk/trunk/frameworks/projects/flex/build.xml
flex/sdk/trunk/frameworks/projects/flex4/build.xml
flex/sdk/trunk/frameworks/projects/framework/build.xml
flex/sdk/trunk/frameworks/projects/haloclassic/build.xml
flex/sdk/trunk/frameworks/projects/rpc/build.xml
flex/sdk/trunk/frameworks/projects/utilities/build.xml
flex/sdk/trunk/frameworks/projects/wireframe/build.xml
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
Removed Paths:
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/PumpStreamHandler.java
