0 Replies Latest reply on Jan 12, 2009 1:51 PM by Chet Haase
    [svn] 4489: Workaround for Flash bug where final column/ row are repeated during the transition, causing a cark border artifact.
    Chet Haase Level 3
      Revision: 4489
      Author: chaase@adobe.com
      Date: 2009-01-12 13:51:55 -0800 (Mon, 12 Jan 2009)
      Log Message:
      Workaround for Flash bug where final column/row are repeated during the transition, causing a cark border artifact. Workaround is to have the shader output alpha=0 for any pixel not in specified bounds (only works if shader specifies width/height, as we do for FxWipe and now do for FxCrossFade).
      Also fixed some minor asdoc errors.
      QE Notes: None
      Doc Notes: None
      Bugs:
      Reviewer: Corey
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxAnimateShaderTransition.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxCrossFade.pbj
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxCrossFade.pbk
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxWipe.pbj
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxWipe.pbk
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAnimateShaderTran sitionInstance.as
