0 Replies Latest reply on Jan 12, 2009 2:47 PM by (GordonSmith)
    [svn] 4492: Simplified how an accessibility class gets hooked into its corresponding component class .
    Level 1
      Revision: 4492
      Author: gosmith@adobe.com
      Date: 2009-01-12 14:47:10 -0800 (Mon, 12 Jan 2009)
      Log Message:
      Simplified how an accessibility class gets hooked into its corresponding component class.
      We now do the hooking in the static method enableAccessibility(), which is called by code that is autogenerated by the compiler. Previously this method did nothing and the hooking happened at static initialization time. This allows us to remove the static var accessibilityHooked and the static method hookAccessibility() in each accessibility class.
      QE Notes: None
      Doc Notes: None
      Bugs: None
      Reviewer: Deepa and Alex
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/AccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/AccordionHeaderAccImpl. as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/AlertAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/ButtonAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/CheckBoxAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/ColorPickerAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/ComboBaseAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/ComboBoxAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/DataGridAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/DateChooserAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/DateFieldAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/LinkButtonAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/ListAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/ListBaseAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/MenuAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/MenuBarAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/PanelAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/RadioButtonAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/SliderAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/TabBarAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/TitleWindowAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/TreeAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/UIComponentAccProps.as
