0 Replies Latest reply on Mar 27, 2008 9:28 AM by (Paul_Reilly)
    [svn] 964: Added -generate-abstract-syntax-tree command line option and generated
      Revision: 964
      Author: preilly@adobe.com
      Date: 2008-03-27 10:28:13 -0700 (Thu, 27 Mar 2008)
      Log Message:
      AST support for *WatcherSetupUtil. This isn't enabled by default yet,
      but it should speed up compilations.
      checkintests Passed: YES
      databinding mxunit Passed: YES, with -generate-abstract-syntax-tree
      true and false.
      Needs QA: Not yet.
      Needs DOC: Not yet.
      API Change: YES
      Code-level description of changes:
      flex2/compiler/Source.java
      Modified constructor to skip setting the fileTime if file is null.
      flex2/compiler/i18n/Compiler.java
      Modified anonymous flex2.compiler.as3.Configuration inner class by
      adding interface method getGenerateAbstractSyntaxTree().
      flex2/compiler/as3/Configuration.java
      Added getGenerateAbstractSyntaxTree().
      flex2/compiler/as3/Compiler.java
      Made CompilerHandler public.
      Modified parse1() to no longer punt if the syntaxTree is not null
      and to only create a new syntaxTree and compilationUnit if they
      are null.
      flex2/compiler/as3/BytecodeEmitter.java
      Modified DebugSlot() and DebugLine() to short circuit if cx.input
      is null.
      flex2/compiler/as3/binding/DataBindingExtension.java
      Added generateWatcherSetupUtilAST() and a truck load of helper
      methods used by it. Many of these helper methods will be moved to
      a common utility class in the near future.
      Modified generateWatcherSetupUtilClasses() to call
      generateWatcherSetupUtilAST() if generateAbstractSyntaxTree is
      true.
      flex2/compiler/as3/binding/PropertyWatcher.java
      Changed bindingExpressions from a Map to a Set.
      flex2/compiler/as3/binding/Watcher.java
      Added generics to changeEvents.
      flex2/compiler/common/CompilerConfiguration.java
      Added -generate-abstract-syntax-tree hidden option.
      flex2/compiler/mxml/rep/BindingExpression.java
      Made class Comparable.
      flex2/compiler/mxml/Configuration.java
      flex2/compiler/mxml/ImplementationCompiler.java
      Modified constructor to pass generateAbstractSyntaxTree into
      flex2/compiler/mxml/InterfaceCompiler.java
      adding getGenerateAbstractSyntaxTree() interface method.
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Source.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/BytecodeEmitter.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/Configuration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/PropertyWatcher.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/Watcher.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Configuration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/BindingExpression.java
