0 Replies Latest reply on Jan 16, 2009 1:42 PM by (Paul_Reilly)
    [svn] 4571: Fixed mxunit tests:
    Level 1
      Revision: 4571
      Author: preilly@adobe.com
      Date: 2009-01-16 13:42:47 -0800 (Fri, 16 Jan 2009)
      Log Message:
      Fixed mxunit tests:
      E4XDataBinding/Expression/model/smoke_Test.mxml
      E4XDataBinding/Expression/var/smoke_Test.mxml
      Namespaces/MXML2006WithGumbo/NS_AS3BuiltInTypesOnGumbonents.mxml
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      Bug fixes:
      API Change: NO
      Reviewer: Carol
      Code-level description of changes:
      frameworks/projects/framework/src/mx/utils/XMLNotifier.as
      Removed cast from watchXML() so XMLList can be passed in.
      modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassEvaluator.java
      Modified evaluate(Context, ArgumentListNode) to push the target's
      type onto the srcTypeStack before evaluating the args and popping
      it afterwards.
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/XMLNotifier.as
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
