0 Replies Latest reply on Jan 16, 2009 4:17 PM by (Evtim_Georgiev)
    [svn] 4576: Fix bug http://bugs.adobe.com/jira/browse/ SDK-18096 Cant set Gumbo FxButton control' s content property dynamically at runtime using ActionScript http://bugs. adobe.com/jira/browse/SDK-18661 FxButton setting data property doesn' t update lab
    Level 1
      Revision: 4576
      Author: egeorgie@adobe.com
      Date: 2009-01-16 16:17:50 -0800 (Fri, 16 Jan 2009)
      Log Message:
      Fix bug http://bugs.adobe.com/jira/browse/SDK-18096 Cant set Gumbo FxButton control's content property dynamically at runtime using ActionScript http://bugs.adobe.com/jira/browse/SDK-18661 FxButton setting data property doesn't update label http://bugs.adobe.com/jira/browse/SDK-18394 The ASDoc for the "data" property of FxButton does not say what the property is for.
      Fix: Remove "content" property. We should use "data" property now instead. Fix label property to be a String typed facade to data property. Make the "label" property the default one.
      QE Notes: None
      Doc Notes: None
      Bugs: SDK-18096 SDK-18661 SDK-18394
      Reviewer: Chet
      tests: checkintest, mustella (FxButton)
      Ticket Links:
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxButton.as
