0 Replies Latest reply on Jan 20, 2009 1:11 PM by Jason Szeto
    [svn] 4600: Flex SDK - Move style metadata from base class down to component classes
    Jason Szeto Level 3
      Revision: 4600
      Author: jszeto@adobe.com
      Date: 2009-01-20 13:11:33 -0800 (Tue, 20 Jan 2009)
      Log Message:
      Previously, all spark and text styles were defined on FxComponent even though not every component supports all of those styles. So I have moved each style to the top-most base class where the style will apply to all descendant classes of that base class.
      This is the set of styles that were added to the various classes:
      baseColor
      color
      focusColor
      symbolColor
      selectionColor
      contentBackgroundColor
      rollOverColor
      alternatingItemColors
      basic text styles
      advanced text styles
      Here are some details about the implementation:
      - baseColor was added to FxComponent because every component and container supports it
      - FxContainer and GroupBase are containers, so their children can potentially support any of the styles. Thus the container classes support all of the styles indirectly.
      - FxDataContainer doesn't support all of the styles because its subclasses (FxButtonBar, FxList) don't support all styles.
      - FxList supports selectionColor, but not inactiveSelectionColor or unfocusedSelectionColor. All other components that support selectionColor, support the other two styles, and thus include styles/metadata/SelectionFormatTextStyles.as
      - GroupBase contains the style declarations that have the full ASDoc. All other declarations use the @copy keyword to reference the asdoc from GroupBase.
      QE Notes: Update tests to remove references to styles that are no longer allowed on various components/FxButton.as
      Doc Notes: Write the ASDoc comments for the style declarations in GroupBase
      Bugs: n/a
      Reviewer: Glenn
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxCheckBox.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxContainer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxDataContainer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxList.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxNumericStepper.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxRadioButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxScroller.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxSpinner.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxTextArea.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxSlider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxTextBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/GroupBase.as
