0 Replies Latest reply on Jan 21, 2009 11:04 AM by (Paul_Reilly)
    [svn] 4608: Fixed asdoc + data binding combination.
    Level 1
      Revision: 4608
      Author: preilly@adobe.com
      Date: 2009-01-21 11:04:19 -0800 (Wed, 21 Jan 2009)
      Log Message:
      tests Passed: checkintests, mxunit databinding
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-18762
      API Change: NO
      Reviewer: Gaurav
      Code-level description of changes:
      Modified evaluate(Context, FunctionCommonNode) to no longer try to
      skip the nodes created for:
      var result:Array = [];
      and
      return result;
      via the for-loop's iterator. Instead, we now skip over the nodes by
      checking the type. For the result variable, the
      VariableDefinitionNode is split into a VariableDefinitionNode and an
      ExpressionStatementNode with a LiteralArrayNode RHS. This is why we
      only want to evaluate ExpressionStatementNode's with a
      MemberExpressionNode RHS.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-18762
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
