0 Replies Latest reply on Jan 23, 2009 5:28 PM by (GordonSmith)
    [svn] 4655: Moved the new UITLFTextField class ( which makes it possible to use TLF in Halo components) from framework. swc to a new SWC, framework_textLayout.swc.
    Level 1
      Revision: 4655
      Author: gosmith@adobe.com
      Date: 2009-01-23 17:28:05 -0800 (Fri, 23 Jan 2009)
      Log Message:
      Moved the new UITLFTextField class (which makes it possible to use TLF in Halo components) from framework.swc to a new SWC, framework_textLayout.swc.
      The reason for this involves how RSLs work. Its presence in the framework RSL meant that, even if a Halo app didn't use UITLFTextField, the TLF RSLs had to be loaded first in order to avoid VerifyErrors. Since we don't want to load TLF for Halo apps that don't use it, we had to segregate UITLFTextField from the Halo framework.
      QE Notes: None
      Doc Notes: None
      Bugs: None
      Reviewer: Glenn
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/frameworks/build.xml
      flex/sdk/trunk/frameworks/projects/framework/build.xml
      flex/sdk/trunk/frameworks/projects/framework/src/FrameworkClasses.as
      Added Paths:
      flex/sdk/trunk/frameworks/projects/framework_textLayout/
      flex/sdk/trunk/frameworks/projects/framework_textLayout/build.xml
      flex/sdk/trunk/frameworks/projects/framework_textLayout/src/
      flex/sdk/trunk/frameworks/projects/framework_textLayout/src/FrameworkTextLayoutClasses.as
      flex/sdk/trunk/frameworks/projects/framework_textLayout/src/mx/
      flex/sdk/trunk/frameworks/projects/framework_textLayout/src/mx/core/
      flex/sdk/trunk/frameworks/projects/framework_textLayout/src/mx/core/UITLFTextField.as
      flex/sdk/trunk/frameworks/projects/framework_textLayout/src/mx/core/Version.as
      Removed Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITLFTextField.as
