0 Replies Latest reply on Jan 26, 2009 11:58 AM by (Paul_Reilly)
    [svn] 4671: * Added PropertyReference() support for CSS.
    Level 1
      Revision: 4671
      Author: preilly@adobe.com
      Date: 2009-01-26 11:58:43 -0800 (Mon, 26 Jan 2009)
      Log Message:
      * Added PropertyReference() support for CSS. PropertyReference()
      support was not added for I18N due to lack of a good use case.
      PropertyReference() works like ClassReference(), except instead of a
      class name argument, a property name should be used. For example
      private var right:String;
        textAlign: PropertyReference("right")
      * Disabled pseudo data binding support in CSS for Flex 4 apps.
      PropertyReference() allows for explicit property references, so the
      implicit pseudo data binding support should no longer be used in
      CSS.
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: YES
      Bug fixes: SDK-17787
      API Change: Yes, added PropertyReference() support for CSS.
      Reviewer: Pete, Evtim, Rob
      Code-level description of changes:
      flash/css/Descriptor.java
      Modified getLexicalUnitAsString() to handle the
      PropertyReference() function.
      flex2/compiler/css/StyleDef.java
      Renamed processClassReference() to processReference() and modified
      it to handle ClassReference() and PropertyReference(). Also,
      disabled the pseudo data binding support unless the
      compatibility-version is 3.0 or less.
      Renamed InvalidClassReference compiler error to InvalidReference.
      flex2/compiler_en.properties
      Renamed css.StyleDef.InvalidClassReference message to
      css.StyleDef.InvalidReference.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-17787
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flash/css/Descriptor.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
