0 Replies Latest reply on Jan 28, 2009 6:13 PM by (Ryan_Frishberg)
    [svn] 4724: Bunch of small changes:
      Revision: 4724
      Author: rfrishbe@adobe.com
      Date: 2009-01-28 18:13:02 -0800 (Wed, 28 Jan 2009)
      Log Message:
      build scripts..just minor fixes and making it player 10
      FxComponent - required parts must be present--not just defined
      FxContainer - removing some dead code around IUIComponent since everything should be an IVisualElement now
      Group - move around logic for removing a previously parented object. This helps deal with graphic elements with shared display objects
      GraphicElement - need to handle display object getting changed as well
      ArrayList/ListCollectionView - add addAll() and addAllAt()
      AdvancedLayoutFeatures - remove Vector import (now that build scripts are fixed, it works fine)
      QE Notes: Write tests for addAll() and allAllAt(), check that required parts are required in the first state
      Doc Notes: None
      Bugs: SDK-18536, SDK-18745, SDK-18709, SDK-18189, SDK-18537
      Reviewer: Evtim
      tests: checkintests, mustella DataGroup, List, Group, FxContainer, FxDataContainer
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-18536
      http://bugs.adobe.com/jira/browse/SDK-18745
      http://bugs.adobe.com/jira/browse/SDK-18709
      http://bugs.adobe.com/jira/browse/SDK-18189
      http://bugs.adobe.com/jira/browse/SDK-18537
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
      flex/sdk/trunk/frameworks/projects/flex4/build.xml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxContainer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/Group.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/GraphicElement.a s
      flex/sdk/trunk/frameworks/projects/framework/src/mx/collections/ArrayList.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/collections/ListCollectionView.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/AdvancedLayoutFeatures.as
      flex/sdk/trunk/frameworks/projects/utilities/build.xml
