0 Replies Latest reply on Jan 28, 2009 6:48 PM by (GordonSmith)
    [svn] 4726: Accessibility changes to the MSAA name of several components, as requested by Freedom Scientific.
      Revision: 4726
      Author: gosmith@adobe.com
      Date: 2009-01-28 18:47:59 -0800 (Wed, 28 Jan 2009)
      Log Message:
      Accessibility changes to the MSAA name of several components, as requested by Freedom Scientific. These changes make Flex controls behave more like standard Windows controls.
      In Accordion and TabBar, the name is now just what is displayed, without " Tab" or " Tab, Active" appended.
      In ComboBox, List, and Tree, the name of each item is now just what it displays, without, for example, "2 of 7" appended.
      Removed an artificial limit of 100000 items in List and Menu.
      A Slider with an MXML id no longer returns that id as its name; no other component does this and id's are certainly no intended to be spoken.
      Removed the getName() method of ComboBase, which isn't used.
      QE Notes: None
      Doc Notes: None
      Bugs: None
      Reviewer: Jason
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/AccordionHeaderAccImpl. as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/AlertAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/ColorPickerAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/ComboBaseAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/ComboBoxAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/DataGridAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/ListBaseAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/MenuAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/MenuBarAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/SliderAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/TabBarAccImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/TreeAccImpl.as
