0 Replies Latest reply on Mar 31, 2008 4:14 PM by (Jono_Spiro)
    [svn] 1048: modules: Removing more unnecessary casts from my previous change.
      Revision: 1048
      Author: jspiro@adobe.com
      Date: 2008-03-31 17:14:13 -0700 (Mon, 31 Mar 2008)
      Log Message:
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flash/svg/SpriteTranscoder.java
      flex/sdk/trunk/modules/compiler/src/java/flash/swf/tools/as3/EvaluatorAdapter.java
      flex/sdk/trunk/modules/compiler/src/java/flash/swf/tools/as3/PrettyPrinter.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/PersistenceStore.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/ResourceContainer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SourcePath.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SignatureEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SignatureExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SyntaxTreeEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/TypeAnalyzer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Attributes.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Method.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Namespace.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/NodeMagic.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/TypeTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Variable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/ASDocExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/ClassTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/CommandLineConfigurator.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationBuffer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/PropertyText.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/SVGTranscoder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Element.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/WebServiceAnalyzer. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/Scanner.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/NodeTypeResolver.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/Model.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Digest.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcCache.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcGroup.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/Benchmark.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/IteratorList.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/MD5Crypt.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/QNameList.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/VelocityManager.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/DependencyWalker.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/MovieMetaData.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PostLink.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMReport.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fonts/BatikFontManager.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fonts/JREFontManager.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/graphics/g2d/GraphicContext.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/localization/XLRLocalizer.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/MovieMetaData.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/SwfDecoder.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/TagEncoder.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/builder/tags/DefineBitsLosslessBuilder .java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tools/AbcPrinter.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tools/Disassembler.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tools/SyntaxTreeDumper.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/util/StringUtils.java
