0 Replies Latest reply on Feb 2, 2009 12:00 PM by (Paul_Reilly)
    [svn] 4795: * Fixed data binding bug caused by ASC issue.
    Level 1
      Revision: 4795
      Author: preilly@adobe.com
      Date: 2009-02-02 12:00:32 -0800 (Mon, 02 Feb 2009)
      Log Message:
      Note: Be on the lookout for new compile errors. Most likely they
      are valid, but were unreported in the past, due to this bug.
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-17798
      API Change: NO
      Reviewer: Erik, Ryan
      Code-level description of changes:
      frameworks/projects/flash-integration/src/mx/flash/FlexContentHolder.as
      Removed unnecessary line with previously unreported error.
      modules/asc/src/java/macromedia/asc/semantics/FlowAnalyzer.java
      Modified evaluate(Context, QualifiedIdentifierNode) to use a
      unresolved namespace for the node's ReferenceValue instead of
      leaving it null, when the qualifier is unresolved. This allows it
      to be resolved later after the namespace is resolved.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-17798
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/FlexContentHolder.as
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/FlowAnalyzer.java
