0 Replies Latest reply on Feb 2, 2009 5:56 PM by (Jeff_Vroom)
    [svn] 4804: Bugs: LCDS-548: add code to deal with contentType="application/ xml" with one parameter (avoid
    Level 1
      Revision: 4804
      Author: jvroom@adobe.com
      Date: 2009-02-02 17:56:22 -0800 (Mon, 02 Feb 2009)
      Log Message:
      Bugs: LCDS-548: add code to deal with contentType="application/xml" with one parameter (avoid
      name/value encoding in that case)
      LCDS-405: baseURL on HTTPMultiService should accept URLs which start with "/"
      Added convertParametersHandler and convertResultsHandler function hooks to RemoteObject
      to support framework code which wants to modify the service behavior.
      Moved "properties" from rpc/http/AbstractOperation to rpc/AbstractOperation so we can use
      it for customizing the handling of remote object results
      Couple of minor ASDoc fixes and one tab -> spaces change
      Doc: minor asdoc edits
      QE: LCDS QE will verify the bugs in this one
      Reviewers: Mete, Pete, Seth, Ed reviewed different parts of this checkin
      Ticket Links:
      http://bugs.adobe.com/jira/browse/LCDS-548
      http://bugs.adobe.com/jira/browse/LCDS-405
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/AbstractInvoker.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/AbstractOperation.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/http/AbstractOperation.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/http/HTTPMultiService.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/http/Operation.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/remoting/Operation.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/remoting/RemoteObject.as
