0 Replies Latest reply on Feb 3, 2009 6:04 PM by (Ryan_Frishberg)
    [svn] 4824: Modifying flash component kit.
    Level 1
      Revision: 4824
      Author: rfrishbe@adobe.com
      Date: 2009-02-03 18:04:24 -0800 (Tue, 03 Feb 2009)
      Log Message:
      Modifying flash component kit. We now implement ILayoutElement directly on UIMovieClip. I also fixed some scaling issues and worked on the Flash Container so we size children appropriately, adding a flag to size the content to the size of the flash container and a flag to unscale the flex content (even though it's parent is scaled due to resizing).
      Because of this, we can remove ILayoutElementUIC. Some point soon, we'll remove LayoutElementFactory and just assume all elements implement ILayoutElement (will do this change when we make IVisualElement extend ILayoutElement).
      QE Notes: None
      Doc Notes: None
      Bugs: None
      Reviewer: Glenn, Evtim
      tests: checkintests
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/ContainerMovieClip.as
      flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/FlexContentHolder.as
      flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutElementFactory.as
      Removed Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutElementUIC.as
