0 Replies Latest reply on Feb 4, 2009 8:03 AM by (Paul_Reilly)
    [svn] 4830: * Resubmitting 4795 with an additional fix for unresolved namespaces
      Revision: 4830
      Author:   preilly@adobe.com
      Date:     2009-02-04 08:03:13 -0800 (Wed, 04 Feb 2009)
      Log Message:
        that come from variables.  For example:
          var ns:Namespace = new Namespace("blah");
          foo.ns::bar();
        This is part of the fix for SDK-17798.  It allows
        DataBindingFirstPassEvaluator to find type information for
        namespaceBT2 in:
        But this isn't a complete fix, because I couldn't figure out how to
        allow the PropertyWatcher for "test_namespace::namespaceBT2" to
        access the property.  The solution will probably be to provide the
        open namespaces to the PropertyWatcher, but I haven't figured out
        how to do this yet.
      tests Passed: checkintests, performance testsuite
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-19047, SDK-17798 (partial fix)
      API Change: NO
      Reviewer: Erik
      Code-level description of changes:
        semantics/FlowAnalyzer.java
          See notes for revision 4795.
        util/Context.java
          Modified processUnresolvedNamespaces() to report an error if we
          can't find a Slot for the namespace, but no longer report an error
          if we find a Slot without a Value.  This happens when the
          namespace is defined in a variable.  ConstantEvaluator will not
          have run yet, so the Slot for the namespace will not have a Value.
          We just silently punt in this case.  The VM will report an error
          at runtime if the namespace can't be resolved.  Unfortunately,
          data binding won't be able to track down change events in this
          case, though.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-17798
          http://bugs.adobe.com/jira/browse/SDK-19047
      Modified Paths:
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/FlowAnalyzer.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/Context.java
