0 Replies Latest reply on Apr 2, 2008 7:31 AM by (Paul_Reilly)
    [svn] 1063: ImplementationCompiler abstract syntax tree generation
      Revision: 1063
      Author: preilly@adobe.com
      Date: 2008-04-02 08:31:38 -0700 (Wed, 02 Apr 2008)
      Log Message:
      work-in-progress. Most of the methods for the equivalent Velocity
      macros in ClassDef.vm and ClassDefLib.vm are stubbed out in
      ImplementationGenerator. Note, with -generate-abstract-syntax-tree
      set to true, mxml compilation is mostly broken. The current default
      is false.
      checkintests Passed: YES
      Needs QA: Not yet
      Needs DOC: NO
      API Change: NO
      Code-level description of changes:
      swfutils/src/java/flash/swf/tools/SyntaxTreeDumper.java
      Added evaluate() for BlockNode, CommentNode, TypeIdentifierNode,
      and UsePragmaNode.
      Modified evaluate() for CallExpressionNode, GetExpressionNode,
      SetExpressionNode, and FunctionSignatureNode to include more info.
      compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      Initial checkin.
      compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension.java
      Moved numerous common methods to AbstractSyntaxTreeUtil.
      compiler/src/java/flex2/compiler/mxml/rep/Model.java
      Made getEffects() public.
      compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
      Added generics to getDeclarationIterator(), getImports(),
      getScripts(), and getMetadata().
      Added getInterfaceNames().
      compiler/src/java/flex2/compiler/mxml/rep/DocumentInfo.java
      Changed return type of getImportNames() from Collection to Set.
      compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      Modified parse1() to call generateImplementationAST() if
      getGenerateAbstractSyntaxTree() is true. Otherwise,
      generateImplementation() is called.
      compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      Initial checkin.
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/DocumentInfo.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/Model.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tools/SyntaxTreeDumper.java
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
