0 Replies Latest reply on Feb 5, 2009 10:15 AM by (Jim_Murphy)
    [svn] 4859: -Fix packaging timing issue that was caused by the rebuilding of the air applicationupdater .
    Level 1
      Revision: 4859
      Author: jimurphy@adobe.com
      Date: 2009-02-05 10:15:22 -0800 (Thu, 05 Feb 2009)
      Log Message:
      -Fix packaging timing issue that was caused by the rebuilding of the air applicationupdater. The recompiled files would get laid down properly only to have the old files put back down on top of them. I also made sure the build directory was removed after updateAIR ran so it would not be included in the package
      -removed bundles.properties from the wireframe project
      bug:SDK-19128
      qa:yes
      doc:no
      checkintests:pass
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-19128
      Modified Paths:
      flex/sdk/branches/i10/build.xml
      flex/sdk/branches/i10/frameworks/build.xml
      Removed Paths:
      flex/sdk/branches/i10/frameworks/projects/wireframe/bundles.properties
