0 Replies Latest reply on Feb 5, 2009 10:51 AM by (Jim_Murphy)
    [svn] 4862: Merge i10 revisions 4827,4834,4837,4845,4859-4860 -> trunk
    Level 1
      Revision: 4862
      Author: jimurphy@adobe.com
      Date: 2009-02-05 10:51:23 -0800 (Thu, 05 Feb 2009)
      Log Message:
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/frameworks/build.xml
      flex/sdk/trunk/frameworks/libs/textLayout_edit.swc
      flex/sdk/trunk/frameworks/projects/framework/src/mx/binding/BindingManager.as
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/FlowAnalyzer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableFirstPassEval uator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableProperty.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeClassInfo.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeSecondPassEv aluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/ManagedProperty.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
      flex/sdk/trunk/modules/webtier/j2ee/servlet/src/java/flex/webtier/server/j2ee/html/ErrorR enderer.java
      flex/sdk/trunk/modules/webtier/j2ee/servlet/src/java/flex/webtier/util/RendererUtil.java
      flex/sdk/trunk/modules/webtier/j2ee/servlet/src/java/flex/webtier/util/index.template.vm
      flex/sdk/trunk/webapps/webtier/build.xml
      Property Changed:
      flex/sdk/trunk/
