0 Replies Latest reply on Feb 6, 2009 5:21 PM by Jason Szeto
    [svn] 4889: Reverting revision 4885
    Jason Szeto
      Revision: 4889
      Author: jszeto@adobe.com
      Date: 2009-02-06 17:21:29 -0800 (Fri, 06 Feb 2009)
      Log Message:
      Something in this checkin is causing an ASDoc compile failure. I will track this down later and resubmit the changes.
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxAnimateFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAnimateFilterInst ance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/BevelFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/BlurFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/ColorMatrixFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/ConvolutionFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/DisplacementMapFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/DropShadowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/GlowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/GradientBevelFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/GradientGlowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/ShaderFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/Parser.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/StrokedElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/GraphicElement.a s
      flex/sdk/trunk/frameworks/projects/framework/src/FrameworkClasses.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      Added Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/GradientFilter.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/filters/BaseDimensionFilter.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/filters/BaseFilter.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/filters/IBitmapFilter.as
      Removed Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/filters/IFlexBitmapFilter.as
