0 Replies Latest reply on Feb 12, 2009 10:17 AM by Peter Farland
    [svn] 4940: In addressing SDK-17370 two things were apparent.
    Peter Farland Level 3
      Revision: 4940
      Author: pfarland@adobe.com
      Date: 2009-02-12 10:17:35 -0800 (Thu, 12 Feb 2009)
      Log Message:
      In addressing SDK-17370 two things were apparent. 1. Batik's parsing of @font-face unicode-ranges needed to be fixed (Batik bug 46055). 2. The syntax that Flex suggests for unicode range pairs was not compliant with the CSS2 specification. The second 'U+' is not needed in the range pair.
      Incorrect:
      unicode-range:U+00F0-U+00FF;
      Correct:
      unicode-range:U+00F0-00FF;
      I've patched Batik to support the variants of unicode-ranges syntax and have rebuilt /lib/batik-all-flex.jar using "ant batik" with JDK 1.4.2_12 from the top level trunk ant script, but I retained support for the legacy (but incorrect) Flex syntax for unicode range pairs.
      QE: Yes, can we go over our unicode-range tests and update them to use the correct syntax in unicode-range pairs? Also please review the CSS-2 specification to ensure we've covered the variants of wildcards and range syntax. http://www.w3.org/TR/CSS2/fonts.html#dataqual
      Doc: Yes, can we please correct all code examples in our documentation for font embedding unicode-ranges to use the correct syntax for unicode-range pairs?
      Checkintests: Pass
      mxunit atembed: Pass (legacy Flex 2.0.1 based tests fail, though they fail prior to this change)
      Reviewer: Paul
      Bugs:
      SDK-17370 - [DefineFont4] Inconsistent font embedding behavior between Gumbo and Halo when embedding a single character in a unicode range
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-17370
      http://bugs.adobe.com/jira/browse/CSS-2
      Modified Paths:
      flex/sdk/trunk/frameworks/flash-unicode-table.xml
      flex/sdk/trunk/frameworks/flex-config.xml
      flex/sdk/trunk/lib/batik-all-flex.jar
      flex/sdk/trunk/modules/swfutils/src/java/flash/fonts/FontManager.java
      flex/sdk/trunk/modules/thirdparty/batik/sources/org/apache/batik/css/parser/Parser.java
      flex/sdk/trunk/modules/thirdparty/batik/sources/org/apache/batik/css/parser/Scanner.java
