0 Replies Latest reply on Feb 12, 2009 5:09 PM by Peter Farland
    [svn] 4944: Minor update to ASDoc to correct class selector example.
    Peter Farland Level 3
      Revision: 4944
      Author: pfarland@adobe.com
      Date: 2009-02-12 17:09:09 -0800 (Thu, 12 Feb 2009)
      Log Message:
      Minor update to ASDoc to correct class selector example. When referring to a class selector using the styleName attribute, the dot is not used in the styleName value. The dot is simply part of the CSS class selector syntax.
      QE: No
      Doc: We may want to do a check through the styles documentation examples in case this same issue is there as well.
      Bugs:
      SDK-16767 - Incorrect class selector examples in CSSStyleDeclaration ASDoc
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-16767
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/CSSStyleDeclaration.as
