0 Replies Latest reply on Feb 12, 2009 6:54 PM by (GordonSmith)
    [svn] 4946: Integrated TLF Build 370.
      Revision: 4946
      Author: gosmith@adobe.com
      Date: 2009-02-12 18:54:47 -0800 (Thu, 12 Feb 2009)
      Log Message:
      The biggest change in the TLF APIs is that the ContainerFormat, ParagraphFormat, and CharacterFormat classes have been combined into a single TextLayoutFormat class.
      The next biggest change is that some formats no longer inherit within a TextFlow, or from a host format to its TextFlow, unless you set their value to "inherit".
      Also, the leadingBasis and leadingDirection formats have been combined into a single leadingModel format.
      A cyclone build passes enough tests that QE has given the go-ahead to check in. The marginXXX formats are broken, but this seems to be a TLF problem and we'll work with the TLF team to get them fixed ASAP.
      QE Notes: None
      Doc Notes: None
      Bugs: None
      Reviewer: TBD tomorrow
      Modified Paths:
      flex/sdk/trunk/frameworks/libs/textLayout_conversion.swc
      flex/sdk/trunk/frameworks/libs/textLayout_core.swc
      flex/sdk/trunk/frameworks/libs/textLayout_edit.swc
      flex/sdk/trunk/frameworks/libs/textLayout_textField.swc
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/TextView.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/TextGraphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/metadata/AdvancedParagraphFormatTe xtStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/utils/TextUtil.as
      flex/sdk/trunk/frameworks/projects/framework/defaults.css
