0 Replies Latest reply on Feb 13, 2009 8:31 AM by (Paul_Reilly)
    [svn] 4950: * Fixed some junit test failures caused by revision 4939.
    Level 1
      Revision: 4950
      Author: preilly@adobe.com
      Date: 2009-02-13 08:31:33 -0800 (Fri, 13 Feb 2009)
      Log Message:
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-19299
      API Change: NO
      Reviewer: Darrell
      Code-level description of changes:
      Modified compile() by moving check for no inputs above the call to
      recompile().
      Modified link() to only call FileUtil.getCanonicalPath() if the
      output is not null.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-19299
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
