0 Replies Latest reply on Apr 2, 2008 5:00 PM by (Jono_Spiro)
    [svn] 1087: compiler: renaming flex2.compiler.abc.Class to AbcClass, flex2. compiler.as3.reflect.Class to As3Class
      Revision: 1087
      Author: jspiro@adobe.com
      Date: 2008-04-02 18:00:38 -0700 (Wed, 02 Apr 2008)
      Log Message:
      compiler: renaming flex2.compiler.abc.Class to AbcClass, flex2.compiler.as3.reflect.Class to As3Class
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilationUnit.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Method.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Variable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/TypeAnalyzer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Method.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/TypeTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Variable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/TypeTable.java
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/AbcClass.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/As3Class.java
      Removed Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Class.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Class.java
