0 Replies Latest reply on Feb 18, 2009 6:34 PM by (Darrell_Loverin)
    [svn:fx-trunk] 5006: Add compiler api to provide swc dependency order.
    Level 1
      Revision: 5006
      Author: dloverin@adobe.com
      Date: 2009-02-18 18:34:14 -0800 (Wed, 18 Feb 2009)
      Log Message:
      Add swcdepends, a command line tool to analyze swc dependencies.
      swcdepends can be run at the command line with no arguments. By default it will use flex-config.xml to tell it where to look for swcs, just as mxmlc does. swcdepends currently has four options in addtion to all the options supported by mxmlc:
      -dependency.show-external-classes
      -dependency.show-swcs [swc-name] [...]
      -dependency.show-types
      -dependency.types [type] [...]
      use "swcdepends -help list details" to see more information.
      QE Notes: None
      Doc Notes: None
      Bugs: None
      Reviewer: Peter
      tests: checkintests
      Modified Paths:
      flex/sdk/trunk/modules/compiler/build.xml
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/SwcDependencyInfo.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/SwcDependencyUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_en.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc_en.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/SwcDependencies.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Toolkit.java
      Added Paths:
      flex/sdk/trunk/bin/swcdepends
      flex/sdk/trunk/bin/swcdepends.exe
