0 Replies Latest reply on Feb 20, 2009 10:01 AM by (Darrell_Loverin)
    [svn:fx-trunk] 5025: Small SWC dependency fixes.
    Level 1
      Revision: 5025
      Author: dloverin@adobe.com
      Date: 2009-02-20 10:01:55 -0800 (Fri, 20 Feb 2009)
      Log Message:
      configuration_en.properties ?\226?\128?\147 add a list of valid values to help for the ?\226?\128?\147dependency.types option
      Optimizer ?\226?\128?\147 add the ?\226?\128?\156compiler.debug?\226?\128?\157 option so a swf can have metadata removed but keep debug symbols. This will be useful to create unsigned RSLs that can be debugged.
      SwcDependencies ?\226?\128?\147 remove compiler.library-path as the default argument. Set the default argument as ?\226?\128?\147file-specs, the same as mxmlc. This files a problem if a swc if given as a command line to swcdepends. Now it will be ignored as are other mxmlc arguments that do not contribute SWCs to the compiler.
      Also fixed a problem where ?\226?\128?\147show-types=true would show nothing if ?\226?\128?\147show-external-classes was false. Now setting ?\226?\128?\147show-types=true will ensure ?\226?\128?\147show-external-classes is true and the types of the external dependencies will be shown.
      QE Notes: None
      Doc Notes: None
      Bugs: None
      Reviewer: Peter
      tests: checkintests
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_en.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Optimizer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/SwcDependencies.java
