0 Replies Latest reply on Apr 3, 2008 12:32 PM by (Jono_Spiro)
    [svn] 1091: compiler: class renaming in the compiler package
    Level 1
      Revision: 1091
      Author: jspiro@adobe.com
      Date: 2008-04-03 13:32:09 -0700 (Thu, 03 Apr 2008)
      Log Message:
      * flex2.compiler:Context to CompilerContext
      * flex2.compiler.util:Console to ConsoleLogger
      Bugs: n/a
      QA: No
      Doc: No
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilationUnit.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerSwcContext.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/PersistenceStore.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Source.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/StyleExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SyntaxTreeEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/TypeAnalyzer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeSecondPassEv aluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/ASDocExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AbstractDocumentBuil der.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMConsole.java
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerContext.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/ConsoleLogger.java
      Removed Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Context.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/Console.java
