0 Replies Latest reply on Mar 1, 2009 7:19 AM by (Stephen_Gilson)
    [svn:fx-trunk] 5119: Clean up some ASDoc tags from the addition of the @ productversion/@playerversion tags
      Revision: 5119
      Author: smgilson@adobe.com
      Date: 2009-03-01 07:19:39 -0800 (Sun, 01 Mar 2009)
      Log Message:
      Clean up some ASDoc tags from the addition of the @productversion/@playerversion tags
      QE Notes: None
      Doc Notes: None
      Bugs: -
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/controls/HTML.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxList.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/TextView.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxResizeInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/SparkSkin.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Accordion.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Button.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/CalendarLayout.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Label.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Text.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ToolTip.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridItem Renderer.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/videoClasses/NCManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/videoClasses/VideoPlayer.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Application.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ContainerRawChildrenList.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IDisplayObjectContainerInterface .as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IDisplayObjectInterface.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IInteractiveObjectInterface.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ISpriteInterface.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextField.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/EffectManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Tween.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/SequenceInstanc e.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/SoundEffectInst ance.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/HistoryManagerImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/HaloBorder.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/Base64Encoder.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/validators/StringValidator.as
      flex/sdk/trunk/frameworks/projects/framework_textLayout/src/mx/core/UITLFTextField.as
      flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/HaloBorder.as
      flex/sdk/trunk/frameworks/projects/haloclassic/src/haloclassic/HaloRectBorder.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/AbstractConsumer.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/channels/AMFChannel.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/channels/HTTPChannel.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/config/ServerConfig.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/messages/HTTPRequestMessage.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/AbstractOperation.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/events/FaultEvent.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/events/ResultEvent.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/http/AbstractOperation.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/remoting/Operation.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/soap/Operation.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/soap/mxml/Operation.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/wsdl/WSDL.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/xml/Schema.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/xml/SchemaMarshaller.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/utils/HexEncoder.as
