0 Replies Latest reply on Apr 3, 2008 1:50 PM by (Jim_Murphy)
    [svn] 1098: Merge 3.0.x -- 362:394, 427:429, 603:608, 644:645, 651:663, 672 :676, 755:756, 763:766, 785:790, 812:814, 854:861, 862:866, 866:933,971: 1009, 1050:1056 --> trunk
    Level 1
      Revision: 1098
      Author: jimurphy@adobe.com
      Date: 2008-04-03 14:50:39 -0700 (Thu, 03 Apr 2008)
      Log Message:
      Merge 3.0.x -- 362:394, 427:429, 603:608, 644:645, 651:663, 672:676, 755:756, 763:766, 785:790, 812:814, 854:861, 862:866, 866:933,971:1009, 1050:1056 --> trunk
      Modified Paths:
      flex/sdk/trunk/frameworks/build_framework.xml
      flex/sdk/trunk/frameworks/projects/airframework/build.xml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/Window.as
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/managers/WindowedSystemManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/collections/CursorBookmark.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/collections/IList.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/collections/IViewCursor.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/collections/ListCollectionView.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/collections/XMLListCollection.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Panel.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBase.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Label.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Spacer.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/TextArea.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/TextInput.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/VRule.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridBase .as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridColu mn.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridDrag Proxy.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListBase.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListItemDragProx y.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListItemRenderer .as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/TileBase.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/TileListItemRend erer.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/menuClasses/IMenuItemRendere r.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/treeClasses/DefaultDataDescr iptor.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/treeClasses/ITreeDataDescrip tor.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/videoClasses/CuePointManager .as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/videoClasses/VideoError.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ComponentDescriptor.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/CrossDomainRSLItem.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IRepeaterClient.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/EffectTargetFilter.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Tween.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/ParallelInstanc e.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/events/NumericStepperEvent.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/events/ScrollEvent.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/events/SliderEvent.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/logging/LogLogger.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/BrowserManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/DragManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/FocusManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/IBrowserManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/ILayoutManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/LayoutManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/preloaders/DownloadProgressBar.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/preloaders/Preloader.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/resources/Locale.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/resources/ResourceManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/DescribeTypeCache.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/ObjectProxy.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/ChannelSet.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/FlexClient.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/MessageAgent.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/MessageResponder.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/SubscriptionInfo.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/channels/StreamingConnectionHandl er.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/errors/MessageSerializationError. as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/events/ChannelFaultEvent.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/messages/HTTPRequestMessage.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/messages/SOAPMessage.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/AsyncRequest.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/AsyncToken.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/Fault.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/Responder.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/events/FaultEvent.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/events/HeaderEvent.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/events/WSDLLoadEvent.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/http/HTTPService.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/http/mxml/HTTPService.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/remoting/RemoteObject.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/soap/AbstractWebService.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/soap/LoadEvent.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/xml/IXMLEncoder.as
