0 Replies Latest reply on Mar 2, 2009 9:28 AM by Peter Farland
    [svn:fx-trunk] 5132: As the first step in supporting namespace qualified typed selectors in Gubmo , this revision updates Batik with basic awareness of the @ namespace at-rule and associated prefixes on type selectors ( but not on attribute selectors as
    Peter Farland Level 3
      Revision: 5132
      Author: pfarland@adobe.com
      Date: 2009-03-02 09:28:01 -0800 (Mon, 02 Mar 2009)
      Log Message:
      As the first step in supporting namespace qualified typed selectors in Gubmo, this revision updates Batik with basic awareness of the @namespace at-rule and associated prefixes on type selectors (but not on attribute selectors as they are not supported by Flex). This revision does not attempt the changes needed in the Flex compiler and runtime to make use of this information to resolve qualified ActionScript class names nor use them at runtime.
      QE: Not yet
      Doc: Not yet
      Checkintests: Pass
      Reviewer: Paul
      Modified Paths:
      flex/sdk/trunk/lib/batik-all-flex.jar
      flex/sdk/trunk/modules/thirdparty/batik/resources/org/apache/batik/css/parser/resources/M essages.properties
      flex/sdk/trunk/modules/thirdparty/batik/sources/org/apache/batik/css/parser/LexicalUnits. java
      flex/sdk/trunk/modules/thirdparty/batik/sources/org/apache/batik/css/parser/Parser.java
      flex/sdk/trunk/modules/thirdparty/batik/sources/org/apache/batik/css/parser/Scanner.java
