0 Replies Latest reply on Mar 2, 2009 10:07 AM by (Evtim_Georgiev)
    [svn:fx-trunk] 5135: PARB changes to FxButton
    Level 1
      Revision: 5135
      Author: egeorgie@adobe.com
      Date: 2009-03-02 10:07:53 -0800 (Mon, 02 Mar 2009)
      Log Message:
      - FxButton is no longer IDataRenderer
      - FxToggleButton is no longer ISelectableRenderer
      - FxButtonBar's default skin now uses a subclass of FxToggleButton that implements both IDataRenderer and ISelectableRenderer
      - "labelField" name of skin parts changed to "labelElement" for all Spark skins.
      - Some minor tweaks, renames
      QE Notes: None
      Doc Notes:
      Bugs: None
      Reviewer: Glenn
      tests: checkintests, mustella (QA ran a cyclone and failing tests are excluded)
      Modified Paths:
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxButtonBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxRadioButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxRadioButtonGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxToggleButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/ItemRenderer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonBarFirstButtonSkin.mx ml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonBarLastButtonSkin.mxm l
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonBarMiddleButtonSkin.m xml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxCheckBoxSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxDefaultItemRenderer.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxFocusSkin.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxRadioButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxToggleButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVSliderSkin.mxml
      Added Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/ButtonBarButton.as
